enabling controls
I have disabled a string control by using its properties.
Again I want it to get enabled once the user clicks OK button. How can i do that in LabView?
Thanks in Advance
Regards
Malleswari
(3,024 Views)
Instead of using the Properties thro' rt-click short-cut menu, try to use the Property Node to do programmatically what you want to. Smiley Happy
That way you can achieve a lot. Smiley Wink
Value 0 means Enabled, 1 means Disabled, 2 means Disabled & greyed Out.
- Partha ( CLD until Oct 2027 🙂 )
(3,019 Views)
Make the string property Disable 0. the string will get enable.
(3,018 Views)
