elvis board
Hi I am new to Labview/Elvis Board and am not very good at using it. What I would like to know is how do I get the LED lights to work on the elvis board? I have been given 4 push switches but I can't find any information on where to place them on the board and how to make the actual LED work. Also I am supposed to connect the board to Labview so that I can use push buttons and rotary dials on the board, which are then simulated in Labview?
Any help would be much appreciated, thanks.
Message 1 of 10
(5,060 Views)
You should be able to find some info here:  Introduction to NI ELVIS II, NI Multisim and NI LabVIEW
Patrick Allen: FunctionalityUnlimited.ca
Message 2 of 10
(5,045 Views)
Hi thank you so much for this, its definitely going to be a massive help! But the LED's that I need to get working are the 7 that are already on the board so would you know how to get them to work by any chance?
Once again, thanks a lot for your help, much appreciated. 🙂
Message 3 of 10
(5,033 Views)
Hi nizza52,
I have got the Elvis II and the Prototyping board. I assume you are referring to the LED's on the right hand side.
To get the LED to Light you need to connect a voltage to the LED pins (35 - 42) these are the ones labeled.
You will also require a connection to ground which is pin 53.
Hope this helps
Nathan
Applications Engineer
National Instruments UK & Ireland
Message 4 of 10
(5,009 Views)
Thank you Nathan, I have managed to get them working. But now I have to use switches on Labview to get the LED;s on th elvis board to work. Any idea on that?
Thanks.
Message 5 of 10
(4,987 Views)
Hi Nizza52,
Glad you have got the LED's lit.
So currently you are using a switch on a LabVIEW VI to control your LED?
What fuctionality are you looking for from your Elvis?
Nathan
Message 6 of 10
(4,980 Views)
Hi thanks for your response. Yes I am now trying to use a push switch on labview to turn on the LED on the elvis board but I am having trouble with how to do it i.e. what to do on the block diagram?
Message 7 of 10
(4,969 Views)
Hi nizza52,
I created a simple VI using a Push button and an the Express DAQ assistant VI.
The settings for the DAQ assistant that I chose were -
-Generate signal
-Digital Output
-Line output
- Picked the NI Elvis I was using
-Port0/line0
-Finish
I then created a control for the Data. This is an array and you can control all the LED's according to the amount of ports/lines you add.
Hardware - I wired DIO 0 (line one) on the right of the Elvis board to LED 0.
There is no need for a ground as this is done internally.
Hopefully this should get you up and running !
Nathan
Message 8 of 10
(4,953 Views)
Definitely helped, I have a much better understanding of it now. Thanks again, much appreciated 🙂
Message 9 of 10
(4,940 Views)
Message 10 of 10
(4,940 Views)
