edit combo box array
Hi Mike,
I m sure that LV 7.1 does not have that property I have mentioned in your code; then, how come you ve got it... ?! Smiley Indifferent
This is what intrigues me a bit.
Is it a private property available only to some users?
- Partha ( CLD until Oct 2027 🙂 )
Message 21 of 31
(1,944 Views)
Hi Partha,
i can´t check it now, but i will do it later.
Mike
Message 22 of 31
(1,942 Views)
Mike,
Can you see its resemblance with that of the Old Value from the Event Data Node? Smiley Wink
Message 23 of 31
(1,940 Views)
Hi Partha,
i don´t understand what you mean. Smiley Sad
Mike
Message 24 of 31
(1,937 Views)
Hi Mike,
See to the attached pic to understand what I mean.
Message 25 of 31
(1,935 Views)
Hi Partha,
sorry i don´t get it. What do you want to tell me with it?
Mike
Message 26 of 31
(1,930 Views)
Hi Mike,
The Old Edit Position property you have used in your VI, is similar to the one that appears on the Event Data node for a value change event of a control/indicator. Smiley Happy
I just compared jovially. Smiley Very Happy
Message 27 of 31
(1,928 Views)
Hi Partha,
see the attached picture, there is nothing special.
Mike
Message Edited by MikeS81 on 05-26-2008 07:53 PM
Message 28 of 31
(1,906 Views)
Hi Mike,
There is something unusual when I load your 7.1 VI in my LV 8.5. Smiley Indifferent
See the red-marked portion in the attached pic. This is what I mentioned & asked you...
Message 29 of 31
(1,888 Views)
Hi Partha,
this is because of the property from 7.1 is not available in 8.5. They have changed the name, but so that the vi is also executable it is possible to use it with the "old" add-on.
Mike
Message 30 of 31
(1,884 Views)
