ebcdic
I was wondering if anyone has worked out a way to read EBCDIC from decimal form.
Thanks Beaton
- there is always an easy way, but it is always the hardest to find
(3,429 Views)
Nevermind I did it myself
Beaton
(3,407 Views)
There is not much call for that old IBM repesentation, mostly ASCII around here.
Did you use a look-up table?
Curious,
Ben
(3,400 Views)
I used a case structure that took the byte in decimal form and output the proper charater in string form. I don't think it is the most effeincent or best way to do it but for what needed it for it was the quickest way to write up something to do the converson.
(3,382 Views)
