easy question - scroll bar position in listbox problem
hello again 🙂
this time my question is simple...
is there a way to set the initial position of a vertical scroll bar of a listbox?
sometimes - if i make more runnings - remain in memory the last position...and if the new listbox is smaller then the last one i see a white listbox and i think that something went wrong in my program
Using LabVIEW 7.1
Message 1 of 13
(5,105 Views)
You can use the 'TopRow' property node fot this.
Kees
Message 2 of 13
(5,102 Views)
where is? :'(
i can't see it
look the attachment
Using LabVIEW 7.1
Message 3 of 13
(5,096 Views)
Hi gigi85
You've to scroll down to see that Top row property 🙂
In the screenshot, after multiple Line input property, still there are few other properties. Please scroll down to see.
uday
Message 4 of 13
(5,082 Views)
no, they don't 😞
after multiple line there is nothing
Using LabVIEW 7.1
Message 5 of 13
(5,050 Views)
Just to verify. You are using LV 7.1 ??
Message 6 of 13
(5,043 Views)
Hi gigi85,
Okay in that case,Please create property node with Multiple lines property, and click on the blue square shown in the diagram and expand it downwards, Labview should automatically add these parameters. added screenshot for your reference.
Let me know if u've any queries.
uday
Message 7 of 13
(5,042 Views)
Pictures in LV 7 and LV 2013.
Kees
Message 8 of 13
(5,031 Views)
yes, i'm using LV 7.1
anyway it doesn't work,,,
i created a property node "multiple line input" (the last one in the properties) and i expand the property node down as udka says.
I obtained a series of multiple line inputs 😞
it's a multicolumn listbox...i don't know if it's different
Using LabVIEW 7.1
Message 9 of 13
(5,018 Views)
Hi gigi,
yes, a "Listbox" and a "Multicolumn Listbox" aren't the same. You should have told that in the first post...
Use "Top Left Visible Cell" instead to set the scroll bar!
Well, you could select different properties instead of "MultiLineInput"! Doh...
Message 10 of 13
(5,008 Views)
