dynamically plot data
I am trying to come up with a method where I can dynamically plot data to a graph depending on the selections that I make from the list items in the cluster.  Can you offer some guidance as to how the data should be formatted so that I can obtain plots based on my list selections?  I have the VI partially working as I can successfully select different Test conditions and the plots come out correctly.  If I however try to access the Temp or Curr list, other than what is set in the default run I have problems obtaining the correct plots.  I know that there is a problem with the way how the data is being parsed for the other selections.
Any help as to how the data should be minulapated so that I can get the correct plots is GREATLY APPRECIATED!!!
hiNi
(3,654 Views)
Please don't keep making new threads with the same question.
Go back to your original thread!
(3,622 Views)
How do I get around the issue if no one is answering my thread?
hiNi.
(3,556 Views)
See my response to your Original Thread.
BS
(3,531 Views)
