dynamic graph origin on xy graph
Hi all,
I'm trying to get my origin of my xy graph to be dynamic more like the "waveform chart" function in labview. Otherwise the plot will get too small and crowded as I'm planning on running the programm for a longer time. Unfortunately the "waveform chart" function doesn't work if I use the "index function" and I quite like the idea of having the elapsed time on the x-axis and not the current time.
Many thanks!
(1,987 Views)
Hi jolli,
You are using a XYGraph, so I see two options:
  1. instead of putting the complete XY data in each plot you might create the plots from subsets of those arrays
  2. switch off X axis autoscaling and set the X axis min/max as needed using property nodes
(1,982 Views)
Hi Gerd,
your first proposition sounds like something I'm looking for, but how do I create these subsets. I would probably like to showcase the latest 20-30 points/entries of the array.
I'm not too sure about that, because then the x-axis would be set and couldn't move anymore?
Thanks!
(1,976 Views)
Hi Gerd,
the first one actually works quite well too! A very basic question, but how as you can see when the time goes on the plot gets bigger, but the viewer still sees the origin and not the current temperature of the plot, he would need to scroll down for that. Is there a solution on how to always see the current state and not the past state?
Thanks!
(1,965 Views)
Hi jolli,
When you want to show the most recent samples then you need to use a subset of those most recent samples…
(The way you build your arrays you might need to take a subset at the end of the arrays.)
You forgot to attach your latest code, but only attach a small image showing the frontpanel: what kind of help do you expect for your code problems?
(1,947 Views)
I have tried to do that, but somehow my Array seems to be recognized as 1D here, as i can't control columns or rows. Furthermore I wouldn't know how to only access for example only the last 20 entries of the array.
For that part I didn't change anything in the code, as attached on the other snippet. I only showed the x scrollbar and turned off autoscale. That would almost do what I'm looking for. But the user has to actively scroll up to get the current temperature.
This last approach seems easier to me, but I don't know how to fix that bug that I don't have to scroll but the programm does it "automatically" for me.
Thanks!
(1,932 Views)
Accepted by topic author jolli12
Hi jolli,
One possible solution:
You could also change the order how you build your arrays by prepending new elements instead of appending. Then a simple ArraySubset getting 20 elements starting from index 0 would be fine…
(1,924 Views)
