SharedVariableO: Only available for Networked Published Variables?
Hey all,
I have a quick question regarding using the DSC SharedVariableO property node to update the scaling of a shared variable. Reading a little deeper, it looks like you can only update the proerties of a "network published" shared variable.
I would like to be able update the property of a I/O variable (specifically a real-time scan I/O variable from my crio, updating the scaling). I have the "enable network publishing" setting clicked in the shared variable properties. However, upon attempting to use the sharedvariableO property node, i receive the error: "Objecft not found. Please check the if the specified name or URL exists for the object, which could be a computer, process, shared variable, citadel database, or NI domain".
Even though network publishing is enabled, am I receiving this error because the variable is an I\O variable, not a network-published variable?
Thanks for your help!
(2,369 Views)
Hey there, just checking if anyone has an understanding of this.
(2,280 Views)
Hi Drew!
I've a similar problem! I want to change programmatically the scaling of I/O variables (current and voltage analog inputs basically) connected to my cRIO chassis. I've enabled the "enable network publishing" checkbox and the DSC module is installed. All the C modules needed are present in the project.
When I run the VI with the SharedVariableIO property node I receive this error: OS and Network Services: (Hex 0x8ABC7010) Initialization failed.
Does anyone know how to fix my problem?
(1,426 Views)
