dublicates elements of an array
Dear friends,
As new user of lab view, I am struggling with this challenge
it would be very difficult for me to explain it and I try to make it clear by an example
array :         2 3 4 5
iteration:      3 2 1 2
out put:       2 2 2 3 3 4 55
my VI is only working for the first element
Message 1 of 16
(5,193 Views)
Step back, write down on a piece of paper how you do this.  Think in terms of loops and iterations.
Some useful functions would initialize array, and also using concatenating tunnels on loops.
Insert into Array should not be used at all in your solution.
Message 2 of 16
(5,189 Views)
I have done all you told me, it seems the solution of this challenge is beyond my knowledge and I have spent more than 5 hours to solve it.
I am not that kind of guy to ask too instead of trying.
Message 3 of 16
(5,175 Views)
Is this a class assignment?
Message 4 of 16
(5,167 Views)
of course NO
Message 5 of 16
(5,163 Views)
Okay then.
It had the smell of homework, and we don't want to do people's homework for them.
Still, you'll learn more if you can figure it out yourself.
I'll give you some tips.  It is a simple VI and I'll tell you exactly what elements you need in there.
1.  2 controls that are your 2 1-D arrays for the inputs
2.  1 indicator that is your 1-D array output.
3.  1 For Loop
4.  1 Initialize Array
5.  Auto-index input tunnels
6.  Concatenating output tunnel.
That is all you need.
Message 6 of 16
(5,157 Views)
Try this. hope two many of your post with similar requirments
Message 7 of 16
(5,144 Views)
Note: A 2D array is symmetrical, so regardless of the Iteration array, the result will be a X by Y matrix where Y is the biggest of Iteration array. The "shorter" rows will be padded. If you want an array of differently long arrays, you'll need to create an array of clusters, including a 1D array.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 16
(5,137 Views)
Hope the array elements has to iterate based on Iteration elements (value) so obvious that the input should be same array size for both Array as well as iteration.
correct me if i am wrong?
Message 9 of 16
(5,135 Views)
Yamaeda,
That is a concatenating output tunnel.  It will not create a 2-D array.
Here is the simplest implementation.
Message 10 of 16
(5,098 Views)
