dsc
Hi All,
I need your Help guys. I have 6 years of experience in SCADA systems, but I'm new to Labview. My doubt is regarding the reporting. In normal SCADA system for Batch Report, Shiftwise reports etc what we do is, store all real time values to a database (MySQL or MS Access). Then in SCADA Mimic if we enter the Batch No. or Shift Number with date, then using some VBA coding  corresponding Report will be generated in MS Excel.
1) I want to know how this can be done in Labview?
2) In Labview is it better to use Citadel instead of MySQL or MS Access?
3) If any of you have a Sample Program for this plz do attach it.
Randheer
(2,496 Views)
Hello Randheer,
Easily you can perform this operation using LabVIEW platform. Its not necessary to use citadel you can go with MYSQL or MY Access. Its totally depend on you what you want to use in your application. You have to use the database toolkits. Database tools are available in the connectivity pallet.
Check some database examples availabe in your PC for Database operations.
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(2,482 Views)
Thanks Man, Yeah I am working on the examples. Will let you know if I have further query.
(2,469 Views)
