Rename Formula.vi "result" to another name
Is there a way to rename the "Result" of the Formula vi?
I want to combine several formula results into a cluster and it gets confusing because each name in the bundle is named "Result"
I'm using Labview 2011 SP1
Thanks! 🙂
(2,490 Views)
Can you show an example of your VI?
If you bundle things into a cluster using the Bundle by Name, you'll be able to define each element in the cluster whatever you want.
(2,486 Views)
Please look at the Read Inputs case. There are two formulas (Formula and Formula 3) that are connected to a "Bundle"
I want to change the calculated value name "Result" in the two formulas to something else, not "Result"
I tried using "Bundle by Name" but it says I am connected two different types.
Thank You
(2,479 Views)
Create typedefs for the desired clusters and use the bundle by name as suggested above. This will allow you to name the elements whatever you want.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(2,476 Views)
