driver for HEITRONICS Infrarot Messtechnik
Hy all,
during a practical Training i am going to use a Radiation Pyrometer from Heitronics series KT.19.XX
and the datalogger SpectroSense2+ from Syke Instruments Ltd.
LabVIEW does not provide any Drivers for the Hardware. There is not enough time to implement
the driver on my own.
Has someone an idea how to deal with this problem?
Thanks in advance.
Julia Sterba
(3,213 Views)
Hi Julia,
There is not enough time to implement the driver on my own.
Well, you can either write your own driver routines - or hire someone to do your task. (Or ask Heitronic for some LabVIEW drivers!)
Heitronics mentions 4 analog outputs and a serial interface for a KT19II pyrometer. You can either use DAQmx hardware to measure those analog signals or simple VISA routines to communicate over serial port…
(3,201 Views)
Use different instruments? If you don't have the time, then what do expect can be done? Have you tried to establish basic communication? You don't need full drivers. Perhaps the Instrument I/O Assistant can help but personally, I think using the lower level VISA functions is just as easy to use.
(3,198 Views)
