03-07-2014 01:09 PM
I have multiple signal that come from the same source and I want to plot on separated waveform charts as on the example that i attached, So far all good, but I would like to be able to use a single scroll bar to scroll all the charts simultaneously in order to compare the values, I have been searching the forums but cant find the way of doing it. Any suggestions? thanks
03-07-2014 01:33 PM
This does the job I think.
03-07-2014 01:49 PM
The information on the other graphs are a bit flickery, not so smooth as is on the waveform chart that controls the others, but for what i need it more than enough, Thanks
03-07-2014 02:02 PM
Try wiring the X Scale.Range.Start property as well and see if that helps.
