If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
download data from internet
I need to retrive the data from instrument which is connect with my PC via the LAN cable. I have a new IP addreess for this device and i don't know how to retrive the data from this device.. i m first learner in labview.. can sombody help me?
(2,818 Views)
Hi treasure,
what type of device is it? Is there a ftp or http server running? Which protocol do you need?
Mike
(2,817 Views)
device is Sunny webbox weather monitoring device. i used http server.
(2,812 Views)
Hi treasure,
you can use the DataSocket functions to get data from your http server. You can also use tcp/ip function and build the http protocol. For that you can find some examples here in the forum.
Hope it helps.
Mike
(2,795 Views)
thanks mike.. i will try to get this.
(2,752 Views)
