dot net event handler
Hi!
Creating .Net objects, I can call a constructor, with EventHandler parameter. Is this parameter revelant in Labview? So Can I use this constructor for Event handling for LV event handlers, or not?  ( Not beacuse I have to register a .Net event with a special method. "Register .Net Event")
ToolStripItem(String, Image, EventHandler, String)
Thanks!
+++ In God we believe, in Trance we Trust +++
[Hungary]
(3,120 Views)
You can create a VI that will receive the .NET event. This VI can in turn be registered in LabVIEW to be handled by an event structure.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/register-event-callback.html
I created an example long ago that uses the .NET PowerModeChanged Event to detect when the computer switches between UPSbattery and AC power. It also works for laptops...
https://forums.ni.com/t5/Example-Code/NET-PowerModeChanged-Notifier-Monitor-your-UPS-or-Laptop-Power...
(3,102 Views)
