dot before name with "unbundle by name" (cluster)
When I connect the "unbundle by name", each name in the elements have a dot before the name. All work correctly but I wonder what are these dots.
Message 1 of 8
(3,751 Views)
Hi yanl14,
maybe you use these dots in the cluster constant. Do you use the "hide full names" feature?
Mike
Message 2 of 8
(3,747 Views)
I use a cluster in type def. with no dot. I unbundle it to load some values I these dots appear.
Message 3 of 8
(3,741 Views)
and in the same vi, I have unbundle with no dot.
(I don't use hide full names function.)
Message 4 of 8
(3,735 Views)
I suspect that the containing cluster does not have a name so the full name becomes ".something". If you select "hide full names" I suspect the leading dot will go away.
Ben
Message 5 of 8
(3,734 Views)
Hi yanl,
Would you mind posting the offending VI (specifically, the minimum required to recreate the issue)?
Jeff | LabVIEW Software Engineer
Message 6 of 8
(3,682 Views)
Ben (as usual) is on to what I think is the correct answer.  Your TypeDef contains an array of clusters of a cluster.  I am not sure why you use two clusters, but apparently you are seeing an artifact of the second cluster label.  With no label, however, I get 00.Name instead of .Name.  At any rate, 'Hide Full Names' should remove it if that is all you care about.
Message 7 of 8
(3,658 Views)
You're right. My cluster in the cluster had no name, it is why I had dot before my names.
Thanks.
Message 8 of 8
(3,633 Views)
