does anyone know how to calculate the impedance using waveforms
does anyone know how to calculate the impedance using waveforms?
Message 1 of 28
(5,694 Views)
What do the waveforms represent?
Message 2 of 28
(5,673 Views)
the waveforms represent the voltage and current values across a capacitive load. I am trying to find out if there is a way to do automatic calculations using the inputs from the waveforms
Message 3 of 28
(5,667 Views)
You would need to know both the Voltage and the Current wavforms.  From there, it is V/I = R.  If you need actual impedance (which has resistance and reactance parts), then you get into fun with complex math.
Message 4 of 28
(5,661 Views)
Hopefully a single sinusoid tone.  Otherwise things get really interesting.  Also know that impedance is based on the frequency.  I'll have to dig into this again.  I have not had to calculate an impedance in well over 10 years.
Message 5 of 28
(5,655 Views)
Can the program do the measurements on the computer?
Message 6 of 28
(5,653 Views)
It can do whatever you program it to do except tell you your requirements.
Message 7 of 28
(5,648 Views)
Once you have the waveform measured, it is just a calculation. Do you also need help with the measurement of the waveforms?
Message 8 of 28
(5,646 Views)
I found out how to measure the waveforms. I'm working on a project for school, the teacher wants me to use the waveforms themselves as an input for the impedance calculations, in order to get the proper phase angle on the current in order to determine the impedance in the circuit. I understand the math behind it for plugging in values myself but I haven't been able to find a way in order to use the waveforms themselves as opposed to the amplitudes measured. I am just trying to find out if there is actually a way to use the waveforms themselves or if I would need to use a formula node to set up all the calculations needed and just plug the values in by hand.
Message 9 of 28
(5,640 Views)
The waveforms you have simply contain the voltage and current values to be used in the calculations.  If you understand the math and can do the calculation using other means (excel or a sheet of paper) then  all you have to do is impliment the same math operations in LabVIEW.  I don't understand where you are having a problem.  Is it in understanding what a waveform is? or is your issue in realizing the math operations?
Perhaps if you re-phrase your question.
Message 10 of 28
(5,613 Views)
