does anyone have a REFPROP already made library ready to be installed on cRIO?
The OS system on my cRIO is VxWorks RTOS, I do not have the right compiler to complile the .DLL file to .Out library for VxWorks systems, i thought some one might had done this already.
i have attached the zip file with all the infromtation required, I want to be able to run the "Refprop_Example_main.vi" from folder "Refprop_Example"  on cRIO. (I can already run it on the Labview on my PC)
(2,850 Views)
Why don't you stick with your original thread?
Why did you create/enter even more threads on the very same topic?
Please stop discussing in several threads in parallel. Keep things in just one place!
(2,840 Views)
Hello again Gerdw
It seems that REFPROP is a better term with this question of mine than NIST, that is why i decided to send it as a new topic in the first place, but then i decided to post it in the old thread and delete this one, however it seems i am not allowed to delete anything here.
(2,829 Views)
