do I need runtime engine xnet
I created a dll with some XNET VIs and property nodes. I try to run this dll on another machine, where XNET is not installed. It is not working -> and I don't even get any error message.
Do I need a kind of runtime engine for XNET?
Madottati
(3,410 Views)
Hi Madottati,
if you are using any kind of LabVIEW VI´s, you need to install the LabVIEW Runtime Engine in the same Version as you have LabVIEW installed.
Nina
(3,378 Views)
thanks for your reply, but that was not my question. It is clear, that I need RTE for LabVIEW.
The question is, whether a dll could be called on a system without XNET installation, if the dll has some VIs using XNET property nodes. I tried it, and it is not working. After installing the entire XNET support for LabVIEW, it is working. I just want to avoid complete XNET installation on deployed systems, if there is a kind of RTE for XNET.
regards
Madottati
(3,374 Views)
Hi Madottati,
you can make an installer and put the xnet driver in the installer. But the driver for xnet has to be installed.
regards,
Nina
(3,346 Views)
