Synchronize 2 function generators
I have created a VI that outputs a sine wave on 2  5421 function generators. The amplitudes can be adjusted on the fly. The problem I am having is trying to keep the 2 signals in phase. I have tried all different combinations of triggering but it always seems to bring up errors/ doesn't work.
I have attached my code with out any triggering.
Any advice would be great on how to align the phases or any better ways to create the sine wave. Eventually what i want to do is to create 2 sine waves one at 0.1V then the second sine wave is at 1 V then a second later the first sine waves amplitude increases to 0.2V and the second decreases to 0.8V and so on untill they have both switched amplitudes.
(2,958 Views)
Hi there,
It may be useful for you to look at some examples from the labview example finder. If you search for "NI-Fgen synchronize" there are examples of a few different methods of synchronising signals between modules using TClk
A good place to start would be:
Fgen Arb Synchronize (TClk).vi (also found here: https://forums.ni.com/t5/Example-Code/Synchronizing-Multiple-FGEN-Arbitrary-Function-Generators-NI/t... )
Fgen Arb Synchronize Master Trigger (TClk).vi
Fgen Arb Synchronize Multiple Rates (TClk).vi
These can be found by clicking Help in the LabVIEW toolbar then Find Examples... then in the Search tab type in "NI-Fgen Synchronize" and scroll through to the above named examples.
You can also refer to
Programming»NI-TClk Synchronization Help in the NI Signal Generators Help https://www.ni.com/docs/en-US/bundle/ni-fgen/page/user-manual-welcome.html
Here is some further information on NI-TClk
https://www.ni.com/en/shop/pxi/national-instruments-ni-tclk-technology-for-timing-and-synchroni.html
I believe if you are using PCI modules (not PXI) then to use NI-TClk to synchronise between two modules you will need an RTSI cable to link them. If yuo are usign PXI 5421 modules then you should not need that cable.
I hope this helps
Tim, CLD, CTD
National Instruments (UK & Ireland)
________________________________________________
"No problem is insoluble in all conceivable circumstances"
(2,914 Views)
