dll function not working
Hi all,
I'm trying to use dlls function, and one of them always returns 1 (error), and I don't know if i'm doing womething wrong.
the datasheet of the dll says :
Prototype: int WINAPI rf_M1_authentication2 ( unsigned short icdev,
unsigned char model,
unsigned char block,
unsigned char *pKey)
Parameter: icdev: [IN] Device ID
model: [IN] key validate mode
block: [IN] block absolute address
pKey: [IN]
6 bytes password
Return: return 0 if successful
Explanation:model = 0x60: via KeyA
model = 0x61: via KeyB
The prototype of my function is :
int32_t rf_M1_authentication2(uint8_t icdev, uint8_t model, uint8_t block, uint8_t *pKey);
Any idea ?
V-F
Message 1 of 9
(4,535 Views)
A short int is usually 16 bits (2 bytes), not a U8.  Can you share your LabVIEW code demonstrating how you're calling the DLL?
Message 2 of 9
(4,529 Views)
thanks for your reply, yes it is an U16.  this is my code :
I joined the dll (renamed in .txt.)
V-F
Message 3 of 9
(4,513 Views)
P.S. The VB code (which works) is :
state = rf_init_com(3,115200);
WORD icdev = 0x0000;
unsignedchar mode = 0x60;
unsignedchar secnr = 0x00;
// int state;
CString strKey;
unsignedchar pData[MAX_RF_BUFFER];
unsignedchar cLen;
strKey ="ÿÿÿÿÿÿ";
secnr = 0;
state = rf_M1_authentication2(icdev,mode,(secnr/4)*4,(unsignedchar*)strKey.GetBuffer(strKey.GetLength()));
state = rf_M1_read(icdev,secnr,pData,&cLen);
rf_ClosePort();
V-F
Message 4 of 9
(4,509 Views)
You said one of the them always returns a 1. Which one? I don't know if this makes any difference in your specific case, but the baud rate in your LabVIEW code does not match the baud rate in the VB code.
Message 5 of 9
(4,491 Views)
it's of course the  rf_M1_authentication2 function.
I tried with others comunucation speeds, but this doesn't change anything...
V-F
Message 6 of 9
(4,486 Views)
Message 7 of 9
(4,484 Views)
V-F
Message 8 of 9
(4,453 Views)
Accepted by topic author ramses64
I finally found the solution by using Labview calls to place my array in a memory area, and transmit the pointer to my dll. Here is the code :
Thanks to all !
V-F
Message 9 of 9
(4,453 Views)
