dll config
I configured the dll but it is not working. What will be the function name. I made dll of the whole project, then what will give for function name
"Thanks with regards "
by
..........Gireesh..........
(3,742 Views)
What are you talking about?  What DLL? Are you trying to make a DLL from LabVIEW code? Are you trying to call a C DLL? Is this supposed to be part of another thread?
(3,732 Views)
I made a dll. I need to call this dll from another vi. For that call library function should be configured. In this function name should enter. In latest version this parameter will come as dropdown list. From there we can select. In the tutorial it is passing parameter as per the dll called/selected. In my project it is acquiring data from the DMM. In this it's functions to measure voltage, current & resistance. So there are three functions. Then which function name should I give?
by
(3,727 Views)
Accepted by gireesh
The function is the name of the VI you exported. The parameter is the input to the VI. This is a control on the front panel. The datatype is the same as the datatype of the control.
(3,725 Views)
Thank you verymuch for the information
by
(3,717 Views)
