distant server
I want to connect LabView to a distant server . Please can any one help me how to do that ?
Message 1 of 8
(6,735 Views)
For what purpose? Database? File io? TCP/IP connection? Distance really doesn't have much to do with how a connection -- other than speed of course.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 8
(6,721 Views)
I have my Raspberry pi configurated as a web server, now I need to connect my LabView application with that server to get data to and from my database in my raspberry pi. any idea please ?
Message 3 of 8
(6,692 Views)
Well, if everything is accessible through the web interface, LabVIEW's http client VIs should work.
Mike...
LabVIEW Champion
Message 4 of 8
(6,682 Views)
I'm really blocked for communication labview and database in distant server. Please help !
Message 5 of 8
(6,642 Views)
OK, well then you are going to have to go through the server on the other end. Does the Raspberry pi support php? In case you don't know, php is text based language that is primarily used to dynamically build webpages.
Now in order to complete that task, it has to be able to access the local database. Hence, another use of php is to create "web pages" that are never meant to be displayed in a browser, but simply return data from the database as a json or XML string.
What you can do is create a php page on the Raspberry that performs the query for you and returns the data.
Mike...
LabVIEW Champion
Message 6 of 8
(6,630 Views)
Well I finally succeeded to make this connection : Labview --> php --> database, now I need to get data from database. Actualy, I have a boolean control (LED) which must chage color when it received "1" from database. I think that there is no big difference but I didn't understant how to connect wires.
Please anyone can help me ?
Message 7 of 8
(6,588 Views)
Accepted by hibaguizani15
The HTTP Client VIs will return a string with the 'response' from the PHP script (e.g. if the script echoes 'hello' then that will be contained in the body string). Your PHP script will need to print/echo the data you want in some sensible format (suggestion: use JSON). You can then use the string to JSON function in LabVIEW to convert the string data into a LabVIEW cluster which you can then unbundle and wire to your boolean.
I suggest you take a look at some of the LabVIEW tutorials - your VI has some serious problems to do with having no execution timing (which means you will poll the raspberry PI as quickly as your computer can), your event structure will never fire (the value change event happens when you click on the 'Boolean' but it's not a button so you can't click on it) and because of that you won't be able to press the stop button.
(blog)
Message 8 of 8
(6,567 Views)
