display
Hi everybody
I have a file in txt format.
I want read this file and present all datas in numeric indicator or string indicator.
I got display like array but as I told before I want to display in numeric or string indicator.
Any suggestion? I have tried use scan from file but failed.
Tks
Fernando
Message 1 of 14
(5,217 Views)
Hi Fernando,
you can read your data as an array and use the index array function to get the single data which you want to show in an indicator.
Mike
Message 2 of 14
(5,211 Views)
You can wire the array to the Array to Spreadsheet String function and show the data in a single string.
Message 3 of 14
(5,208 Views)
The problem still remain.
In my txt file I have 10000   8895.
I got displya both number in a string indicator.
I want display 10000 in a string or numeric indicator and the number 8895 in another string or numeric indicator
tks
Message 4 of 14
(5,198 Views)
That's a bit different than saying you want to display a 2D array in a string indicator. You want 2 elements in the array displayed in two different indicators. Just use what MikeS81 suggested.
Message 5 of 14
(5,193 Views)
I tried  to do what MikeS81  suggest. But it failed.
Here is what I tried to do. Where is my mistake?
Tks
Message 6 of 14
(5,146 Views)
Hi muganga,
why do you use the property node? If you connect the index you need to the first index function you use, you get exactly the value you want.
Mike
Message 7 of 14
(5,144 Views)
Correct MIke
Here is what you suggest to do.
Now it is working perfectly.
Just one more question.
Do you know ho to do a listbox?
Many tks
Message 8 of 14
(5,140 Views)
Hi muganga,
do you mean something like this? If you only need string you can read your file as string instead of double.
Hope it helps.
Mike
Message 9 of 14
(5,137 Views)
MikeS81
What I need to do is list all filenames in a lisbox. After that select a filename in the listbox and this filename will be the file where I gonna read using READ FILES
Many tks again
Message 10 of 14
(5,135 Views)
