KPCI 3110 labview driver (not working when I downloaded from the website or installed from the dic)
Hi, I have a question about the LabVIEW driver for KPCI-3110 we recently bought. I tried to use either the samples offered by the website or coming with the dic. It turned out that I could not open with LabVIEW 8.5. Then I tried to open with LabVIEW 7, they were opened, but with some sub VI missing. Does any body can offer some working driver? The function I need is to read the voltage/value of the single/multiple channels. Thanks a lot!
(2,917 Views)
Try this
Hope this helps!!!!
Mathan
(2,905 Views)
That is the one I tried. those VIs can not open properly with LabVIEW 7 and can not open at all with LabVIEW 8.5 Smiley Sad
(2,898 Views)
Did you also install the driver or did you just try to run the example? According to Keithley's web site, you need both DriverLynx and the LabVIEW VIs for DriverLynx.
Support for Keithely products is best gotten from Keithley and not NI.
(2,893 Views)
