display message once inside loop
I'm trying to display 2 messages to the user indicating 2 distinct conditions in my program. However, since the entire program runs in a single while loop, the messages appear over and over again. If I take the message boxes out of the loop, they both appear after one of the conditions is met. I would like each message to appear once when their corresponding condition is met, have the user click OK, then have the message disappear and have the program continue running.
Any ideas on how to do this?
Daryn
(4,417 Views)
Put it in a case structure wired to the iteration terminal. Make the empty case the default and the other case (the one with the dialog!) "0", for example.
(4,411 Views)
Hi Daryn,
You could use a separate loop driven with a queue:
Example attached in LV2010.
steve
Founding (and only) member of AUITA - the Anti UI Thread Association.
(4,396 Views)
Is it necessary for the user to do something or are these simply status updates. If you do not need the user to respond you may consider updating the status in some other way than to use dialog boxes. Over use of them can be quite frustrating for the user, especially if they simply are updating some status.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(4,383 Views)
Ok I got it to work....thanks everyone!
(4,337 Views)
Whose advice did you use?
Cameron
To err is human, but to really foul it up requires a computer.
The optimist believes we are in the best of all possible worlds - the pessimist fears this is true.
Profanity is the one language all programmers know best.
An expert is someone who has made all the possible mistakes.
To learn something about LabVIEW at no extra cost, work the online LabVIEW tutorial(s):
LabVIEW Unit 1 - Getting Started</ a>
Learn to Use LabVIEW with MyDAQ</ a>
(4,333 Views)
