07-11-2005 08:00 AM
07-11-2005 08:08 AM
Will this work for you ??
Dan
07-12-2005 01:09 PM
Hi Sudhir,
I found an example which does similar to what you are looking for. Unzip the zipped file and you should see two examples.
File Read Customized will help you to read data from file and format into single column.
File Read Customized_multiple line will help you to read data from a file which has multiple rows and columns. Then it updates table on the front panel with new line read.
Please feel free to use it. I am also attaching a sample text file for you to try the example.
Kalyan
