How to run a numeric case structure
How can i control the numeric case structure using prompt user as my numeric input?
Message Edited by unknown\ on 07-12-2005 10:25 AM
(3,086 Views)
I'm not realy understanding what you want to do there.
The signal you're connecting to the case structure is not numeric.
To control a numeric case structure you must connect a number to it.
Paulo
(3,068 Views)
Maybe you want something like in the attached code sketch?
(3,059 Views)
I agree with Paulo. Your example is very confusing. What are you hoping the merge signal function will do? I don't think it will work they you want but I don't know what you want. You can't wire the output of the merge signal directly to a case selector unless you convert it to a numeric and if you have a numeric as a case selector, you can't wire that to a Boolean input inside the case structure.
(3,056 Views)
