disableing front panel control when program runs
I would like to allow the user of my program to enter some variables into the program before it runs and then disable/grey out the control when the program is running so that the value that they have set cannot be changed until the program has finished or has been stopped.
Is there a way of changing the state of a control so that it can be edited before the program is run and then not edited when the program is running?
Paul
(2,554 Views)
A property node of a control can be used to do just that!
Right click on the control>>create a property node>> select property 'disabled>> change to Read>> wire a constant of '1' and your control will be diabled when you run the vi
Pass '0' at the end to enable it
Do as shown in pic attached
(2,552 Views)
