disable warning dialog
I receive this warning The VI is expected to be at "here " it was loaded from "there ".  Is there a way to ignore the error or programatically click OK.  This occurs when comparing multiple VIs.
(2,376 Views)
1. Try to keep all the VIs at specific path
2. Also when it shows the Loading path it wants a confirmation from you that LabVIEW does not find any VIs/File from the designated path but it finds it somewhere in the Drive.
3. This is a good practice to keep all source files in one location for Example: On 1 PC the Path for VIs is C:\ABC\.. create the same Hierarchy on another PC so that yoy will not get warning next time
(2,351 Views)
