04-10-2002 01:06 AM
04-11-2002
11:55 AM
- last edited on
10-21-2025
12:34 PM
by
Content Cleaner
This is hard to answer because it all depends on whether or not the SIEMENS S7 PLC can communicate using a the AS511 protocol. This protocol is supported by National Instruments Industrial Automation OPC Servers. However it doesn't state any specifics about the S7 PLC. You may want to check with SIEMENS for a serial OPC driver which you could use with LabVIEW.
The list of supported PLC and Protocols are listed here:
Where can I Find Drivers for Communicating to PLCs, RTUs, and Other Industrial Hardware?
Here is information about using OPC with LabVIEW:
Connecting LabVIEW to an OPC Server through a DataSocket Connection
Good luck,
Mike
04-12-2002 06:53 AM
07-25-2002 04:48 AM
08-08-2002 06:56 AM
08-22-2003 04:31 AM
