01-04-2011 02:00 AM
hi..
i'm newbies in labview..just want to ask a few questions. i have 4 differential equations (non-linear), and it is a mass balance eqn. of activated sludge process. my question is how to design the block diagram(diff eqn) and then connect all together to get one output?
01-04-2011
05:12 AM
- last edited on
05-06-2025
06:29 PM
by
Content Cleaner
You can use formula node to write equations.
Check here
01-04-2011 09:12 AM
Another approach is to reformulate your differential equations as difference equations. Then you can loop through the arrays and perform relatively simple calculations on each element.
Lynn
