differential equation
Dear Sir
I'm beginner in labview and I would like to solve the following two differential equations and plot them over time:
dx1/dt= (G-K*x1(t))/V(t)
dV(t)/dt = (1/((1-(((G-x1*(K-U))/(G-x0*(K-U)))^((U/(K-U)))))-1))*U
G=7.8
U=0.166
x0=132
Vo=432
K=2.02
Could anyone please help me and send the block diagram for these two equations.
The graphs of both variables must be decreased over time. The graph of X1 is exponential decay.
(4,856 Views)
A good place to start might be here:
http://zone.ni.com/reference/en-XX/help/371361B-01/lvanlsconcepts/solving_odes/
- or -
 Go to the Mathematics pallette then theDifferential Eqns sub-pallette and see if what you need is there.
(4,808 Views)
Could you please draw the block diagram for it because I'm a beginner in labview?
(4,802 Views)
While many people here will post an example of a screenshot of code, they will hardly ever write your entire application for you, especially if that is what you are looking for.
The forums are here for assistance, to get people over hurdles. When that hurdle is just being new to LabVIEW, we will reccomend tutorials and training.
Chris Van Horn
Applications Engineer
(4,798 Views)
I'm now reading and learning the basics of labview. but if you have any simple example using the ODE solver becase all the build in examples are very complex and I can't understand it.
I just need any helping examples about writing differential equation using ODE solver function?
(4,790 Views)
Accepted by Dr_Azar
Hello Ahmad,
I made a simple example and put it on our community page.  This example uses our ODE solver VIs.  LabVIEW comes with 8 built in ODE solvers.  These are all linear system solvers.  It appears that your equations are not linear. I would suggest using LaPlace transforms to solve the equations.
Example Code
Jon S.
LabVIEW NXG Product Owner
(4,760 Views)
Thanks very much for your help and your interest. I will try to make it.
Ahmad
(4,745 Views)
