different plots in one graph
Hello.
 I want to get different plots, as many as the number of the columns of an array, ( except column 1 is for X axis) in one XY graph , But I want to do this automatically,  without having  many cases in the Case Structure.
For example, if I have 30 columns in my array, i will get 29 different plots ( column 1 is common for all the plots).
Any idea of how to do this ?
Thank you in advance.
Message 1 of 25
(4,263 Views)
Accepted by topic author Student_LV
You don't need any Case Structure, just use a loop:
Paolo
Message 2 of 25
(4,239 Views)
I thank you for your solution
I want also to know which is the property node i have to use to set the pace in X and Y scale ?
EG : For Y scale, I want values to go from 0 to 200 with a pace of 5
Thank you for your help
Message 3 of 25
(4,227 Views)
Check all the properties under Y-scale -> Range
Paolo
Message 4 of 25
(4,220 Views)
I checked all the properties under Y scale --> range, i didn't find a specific property for pace
Message 5 of 25
(4,214 Views)
Hi Student,
Maybe because you are looking for "increment" (or even "minor increment")?
Message 6 of 25
(4,211 Views)
Another hint: there is a help item for each property (right-click on the property name).
Paolo
Message 7 of 25
(4,207 Views)
Hello everyone!
You will find above the XY Graph that i have obtained :
how can I optimize it in order to get a readable and interpretable Graph ?
What property nodes I can use to not get too close plots?
Another point, each plot correspond to distinguished class values, I want to give a name to each plot ( eg : class 1, class 3, class 20 ...), How can i get a legend for all the displayed classes ?
Any suggestion will be appreciated
Thank you so much
Message 8 of 25
(4,159 Views)
Hi student,
Get better data…
Which kind of "readable and interpretable graph" do you expect?
Get better measurement data! (Or use less plots.)
Property nodes will not help to separate those plots…
- You could resize the plot legend to show more plots!
- You can provide a label for each plot using property nodes of the graph…
Message 9 of 25
(4,156 Views)
Thank you for you response,
What I expect is spaced plots ( not too close as in the attached figure)
How can i provide a label for each plot, using property node, knowing that there are too many ones ?
Message 10 of 25
(4,146 Views)
