different frames
Hi:
How I can make a program on LabView that includes more than one frame?
Bye frame I mean the front panel.
Can you send me an example?
Tanks!!
(4,029 Views)
You can use Tab Control to get multiple frame. Its under "control" (in front panel) -- under "array and culster" .
Or you can open multiple front panel using your sub vi front panel.
When you feel sad, laugh
(4,029 Views)
HI Baroque...
Here is an example. Just open Master.VI and run it.
It demonstates how to dynamically load VI into memory, show their front panels (frames) and get them running.
This example (LV 6.1) opens a referece to a set aof VI's and uses an property node to show the front panel and an invoke node to start them. The VI then enter a loop to demonstrate that it is running.
Each of the dynamically called VI will also show that they are running. These VI can be closed individually with out affecting the othres.
When the Master.VI is stopped, it closes all of the other VI's again using control references.
Have fun,
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
(4,029 Views)
Hi:
thanks for your response, now I´m using a subpanel.
See you
Gabriel
(4,029 Views)
Hi:
Thanks for your response, that's so funny but I`m now using subpanel.
See you
Gabriel
(4,029 Views)
Thank you Gabriel!
That is the only code I have ever written that I do NOT mind people laughing at.
Ben
(4,029 Views)
