different VI server port definition?
Confused by the different documentation online for VI server port.
Here, it is using the tools->option->VI server
https://www.ni.com/docs/en-US/bundle/labview/page/configuring-the-vi-server.html
Here it's using VI Server >> Application class property node
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DdiqSAC&l=en-US
So should these ports be the same or can be different?
I know the one defined by tools menu is the same as what VIPM uses to talk to labview when installing.
Which leads me to think they are different.
(543 Views)
Accepted by topic author shuttlefan
Found the answer buried at the bottom here
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019LbZSAU&l=en-US
Additional Information
  • Creating VI server settings from the Tools-Options->Vi Server menu only applies to VI's that are not being run from within a project. If you want to set these settings for a VI within a LabVIEW project, you will need to generate set these settings through VI Server property nodes.
(515 Views)
