Bug: Copy from LabVIEW & Paste to Paint changes the picture
Why the pasted picture is not identical to the source?
In LabVIEW the yellow cursor is at YX(0 ; 215u)
I select the control > Press CTRL+C > and in Paint I press CTRL+V
But after pasting to Paint the cursor is at YX(3 ; 215u)
To be exact in LabVIEW the cursor is at XY(11m ; 215u) but that is almost X=zero.
LabVIEW Professional Development System - Version 2024 Q1 (64-bit) 24.1f0
Message 1 of 8
(1,485 Views)
I have noticed this behavior many times.  I usually avoid it by doing a screen grab (usually alt-printscreen for the active window) and editing it in Paint, or using the built-in Windows snipping tool to select part of the front panel and copying it.
Message 2 of 8
(1,454 Views)
Yes, windows scaling seems to apply somehow, i've seen it before.
Qestit Systems
Certified-LabVIEW-Developer
Message 3 of 8
(1,452 Views)
It seems cursor moved horizontally.  Make Cursor Legend visible.
Is the cursor snap to a plot?
How many data points in the graph?
Does this occur when zoom in?
George Zou
Message 4 of 8
(1,420 Views)
on windows try <window key> + s
and you can select the area to capture without having to use paint to crop a print screen:
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 5 of 8
(1,317 Views)
Here's my wild guess:
When you perform a 'Copy' of objects on the front panel, LabVIEW doesn't make a copy of the image of the front panel.  Instead makes copies of the objects from the front panel and places them into the clipboard.  It also generates an image based on those copies of the object and adds that image to the clipboard.  The image could look different than the front panel if something changed shortly after the user performed the 'Copy', or if the process of making the copies caused a change.
Here's an example:
Item copied from block diagram: paul_a_cardinale_4-1759161237606.png
Image pasted from clipboard: paul_a_cardinale_2-1759161174534.png
Message 6 of 8
(1,303 Views)
Copy&paste graphs directly from the front panel definitely has multiple issues.
For example if an axis is set to auto-scale, but we are zoomed in to a smaller area, the pasted picture will again be auto-scaled to the full range. Using the windows screengrab gives you what you actually see.
Message 7 of 8
(1,284 Views)
Unfortunately, my licence expired a few months ago, so I can no longer report the bug to NI.
Could one of you do that and forward a link to this thread?
As most of you I like it to have clean copies of the copied elements.
Message 8 of 8
(1,179 Views)
