difference between VISA READ buffer and string
Hello I am just starting to use the VISA read and write function in labVIEW
anybody knows what are the differene between VISA Read buffer and string? and comparison of VISA Write buffer and string
thanks
(4,634 Views)
Accepted by topic author MiBL
Hi Ein,
"read buffer" is the label of the string given by VISARead, "write buffer" is the label of the string expected by VISAWrite!
So there is no difference...
(4,631 Views)
Hi Gerd,
Thanks heaps for ur solution 🙂
(4,623 Views)
There is a difference if you try them both with a simple scpi command one works and one doesnt. I have to use string to write to get the command to work.
(3,807 Views)
Hi Dr.,
can you elaborate on what you wrote before? What are you talking about when bringing this old thread back to life?
(3,797 Views)
