difference between Mass compile in Project %26 in LabviewTools Advanced mass Compile
what is the differece betwen the two,  Mass Compile option in a Project(LVPROJ) and  LabviewTools Advanced mass Compile
The Issue is if I do the Mass compile thr' the Project I do not get an Error.
But if I  mass compile thr' labview >> tools>> adv. Settings>>mass compile  it shows BAD VI ??
(3,489 Views)
I would think that the project mass compile will only compile VIs that are in the project (and perhaps dependencies?!) whereas the one from the tools menu will compile an entire folder - this would include any broken VIs (that aren't in the project).
(blog)
(3,468 Views)
My Project folder is clear of   Erorr VIs  -->>  there are none
inspite of that  the difference exist.
I am using classes in my Project &   may be  the   class contains information abt  the VIs (the broken ones)
My Class is added ina llb file which is  part of my project...
In runtine I get issues  with the project.
(3,450 Views)
I think may be I got it ,
there were some unused VIs in the library  (.llb) which  have to  be removed. & then hopefully its ok
(3,427 Views)
