09-17-2019 05:57 PM
I got this messages. ( iberr=EBUS) during detector calibration on my ILX LPA-9084 laser characterization system. Using Lab View. What I should to due to go forward. Thank you laserpeter
09-17-2019 07:28 PM
Read the manuals and find out what that error means. Doesn't sound like a LabVIEW error message ... Are you running LabVIEW code? Post it so we can see what might be wrong (or, I suppose, we could guess ...).
07:28 PM
- last edited on
06-16-2025
12:27 PM
by
Content Cleaner
According to document below, the message implies that there is a command error.
How to Programmatically Check the Status of Your GPIB Board
I don't know how are you doing the calibration but if you are sending some command,
confirm the message is valid.
09-18-2019 06:01 PM
Hi,I get on NI-Max and proceeded the steps to get in to put in the recommended command for calibration of the detector. The massage was; " NI-488 function on IBONL is called for disable the hardware and software." Get this on the screen; iberr:EABO. EABO indicates that on I/O operation has been cancelled.
I do not know what I need to due fix my problem?
c:\users\pltlaser\appdata\roaming\qualcomm\eudora\attach\20190918_150714.jpg;
Thank you
09-18-2019 07:10 PM
03-08-2024 08:50 PM
03-09-2024 02:40 PM
You have not provided us much information for us to suggest how to get your unknown instrument that "uses LabVIW and NI Software" to help you establish contact and "calibrate the detector". We know nothing about the Instrument, have no access to its manuals (I tried to find information on the Web, but my searches were not successful), and have seen nothing of the code you are trying to run.
Do you know anyone with LabVIEW experience whom you could ask to look over your manuals and instruments and try to help you?
03-09-2024 03:55 PM
Hi Bob, the instrument was made by ILX Lightwave Co. The system LPA-9084 a Semiconductor Laser Characterization System. ILX Lightwave developed this system and sold WW. The LPA-9084 is the instrument model. This system is testing semiconductor lasers Wavelength, Power, Efficiency. etc. The ILX Lightwave Co. was sold, and nobody have the knowledge or doesn't want to help. In the past when the company existed to calibrate the detector with the employees of ILX help was taken only a few minutes.
Thank you.
Peter
03-10-2024 05:36 AM - edited 03-10-2024 05:38 AM
This seems like a case that can’t really be solved through the forums. The information you provide is very limited and due to you’re being unfamiliar with LabVIEW, GPIB and programming in general also somewhat cryptic.The fact that the system uses GPIB programming API rather than VISA also would hint that it is probably at least 25 years old. Nobody with a sane mind programmed GPIB on that level in this century since VISA was simply a so much better alternative and most instrument manufacturers had figured out how to implement IEEE-488.2 in order to make use of VISA on the PC side almost a breeze. Debugging GPIB API issues is an art that only old foxes still know about although in my case hasn’t been exercised in over 20 years.
I think the only valid way forward-will likely be to find someone who has experience in GPIB programming, and LabVIEW and hire them. And without source code of the LabVIEW application and a real manual of the device it may still be hopeless.
03-13-2024 03:01 PM
Have source code and manual.
