detect when a for loop has finished
I want to be able to turn on a led when a for loop has finished, I wired an array to the for loop, so I don't know how many times it will iterate, because I wired an array, which comes from all files in the recursive file list. Can someone please help me figure this out?
(4,773 Views)
Think dataflow, simply have your LED write depend on data passed from the loop (an error wire for instance).
(4,762 Views)
Can you please give me a pic showing this?
(4,759 Views)
Accepted by Nando88
Don't worry about the last function, it's just a placeholder. The idea is that it won't execute until the for loop has finished because it is waiting on information from the error wire.
(4,752 Views)
Hello nando
 I attached you a pic, we are comparing the iteration terminal, and if it becomes greater than 0, we will have a True as output
(4,667 Views)
@KIKEV89 wrote:
Hello nando
And suppose the loop runs exactly 1 time?  Then the i value will be finished at 0, it is not greater than 0.  The boolean won't light even though the loop is done running.
(4,658 Views)
