designing digital filter for analog output
Hi all,
Iam working on pci-6723 NIDAQMX 7.3 LABVIEW 7.1 ENVIRONMENT.I have designed 16 channel data acquisition system.in order to supress glitches in the analog output signal ,which filter i have to adopt to the analog output generation. since i dont want to design hardware low pass filter , if i adopted digital filter will it improve the output signal performance ,kindly suggest me.with some example.
Regards
labview boy
(2,470 Views)
If you are talking about a software digital filter with the program that is producing the analog output, that will have no affect on an analog output signal. The glitching comes from the digital to analog converter (DAC). Check out this knowledge base article:
http://digital.ni.com/public.nsf/allkb/3BB2D5D837F6C9FE86256EAC007C123B
Really, your only solution is hardware.
If you are acquiring this signal on another data acquisition system and you want to remove the glitches from what you are seeing, you could use software filtering there.
-Alan A.
(2,441 Views)
