design control and simulation palette
After hitting Next bottoms and succesfully installation for Design control and simulation toolkit , when I launchำก Labview programme  there is nothing in this function and the palette is blank. Anyone knows what happen.  I use Labview 2013 student edition 64 bit(free 6 months version). Thanks in advance+++
(4,332 Views)
Do you truely have the 64bit version of LabVIEw installed?
If you do, then you will not be able to use this module.
It is only valid for 32bit LabVIEW.
You can see the system requirements here:
http://www.ni.com/labview/requirements/#cds
You can try to install 32bit version of LabVIEW and then install the module.
(4,307 Views)
Accepted by Tullip
Thank for advice .Okay I will try to reinstall 32 bit version but why we have Lab VIEW 64 bit but there  is no CD&SIM  compatible with it.
(4,284 Views)
After installing LabVIEW 2013 Version 32 bit, CD&SIM poped up on the palette thanks dkfire for your kindness.:smiley happy:
(4,274 Views)
If an answer to your question has the solution to your problem, then please mark the correct answer as the solution.
It is rude to mark your own feedback as a solution, and it will confuse other users with the same problem as yours.
Also for future questions, if a user is giving you an answer that helps you on the way in anyway, then give that user a Kudo.
(4,269 Views)
