取消
显示结果
搜索替代
您的意思是:
delete white spaces between two strings
hi!
How do I remove white spaces between two strings. I have attached file for reference.
0 项奖励
1 条消息(共 10 条)
6,074 次查看
There is a trim whites spaces vi
- there is always an easy way, but it is always the hardest to find
0 项奖励
2 条消息(共 10 条)
6,064 次查看
Hi!
Thanks for your repy.
I have tried trim white spaces fn. but it didn't work
0 项奖励
3 条消息(共 10 条)
6,054 次查看
Hi bhotu,
use the search and replace function with "true" for replace all. Switch you original string control to "CodeDisplay" to find out which character you have to replace.
Mike
0 项奖励
4 条消息(共 10 条)
6,046 次查看
You should use that vi for every line and if one line consists of only \r\n, delete it.
0 项奖励
5 条消息(共 10 条)
6,042 次查看
Hi! Pnt
But I don't want to replace anything. Just I want to delete white spaces. I have used trim white spaces fn. It works. But it printed output in single line. I have attached file for your reference
0 项奖励
6 条消息(共 10 条)
6,032 次查看
Hi bhotu,
can you please upload your vi, so that we can see which characters are in your string?
Mike
0 项奖励
7 条消息(共 10 条)
6,030 次查看
You could try to use a compare statement to see if a line is empty, anddelete the ones that are, or do the opposite for lines that have values other than space or null. This would delete the empty lines, which is different than trimming the white spaces
0 项奖励
8 条消息(共 10 条)
6,020 次查看
You first need to define what you consider to be "whitespace". Is it just a space? Is it spaces and linefeeds? What about carriage returns? Tabs? Anything non-alphabetic and/or non-numeric?
As mentioned previously, the Search and Replace String can be used to delete characters by wiring an empty string to the replace string input. The following, for example, will delete all spaces:
If you need to delete other whitespace characters, just call it again on the resulting string.
Message Edited by smercurio_fc on 06-02-2008 09:25 AM
0 项奖励
9 条消息(共 10 条)
6,003 次查看
Hi! Beaton,
Thanks for your prompt reply.
finally i did it and it works. I have used trim white spaces  function and  search and replace string fn. with end of line. it works.
0 项奖励
10 条消息(共 10 条)
5,989 次查看
