delete excel table column
I have an excel templpate that contains a table that is already formatted with lots of formulas and colroed celss, etc.  Depending on the query that I run with labview, I produce a data result that is exported to excel and then I want to resize teh excel table to fit the data.  I want to resize a table with activex commands in labview.  How do I do this?
Message 1 of 10
(4,583 Views)
Your question doesn't quite match the Subject of your thread, but anyway, what do you mean "resize the table?" By its very nature, Excel is a borderless table.
Richard
Message 2 of 10
(4,579 Views)
In Excel 2007+ there is a table object that can be resized by manually selecting the table and going to the table tools>design tab to change its dimensions...
After I write my data I would like to programmatically resize the table width in my template file once populated to the same size as the data written into it.
Message 3 of 10
(4,577 Views)
the table object in excel iks what I am talking about specifically.  It is on the level as a range in the app but I dont see it in the activeX breakdown
Message 4 of 10
(4,565 Views)
If your table contains lot of formulas you might end up with invalid references if you delete and shift columns.
Ben64
Message 5 of 10
(4,561 Views)
I dont have fomrulas other than conditional formatiing colring the cells if they match a certain string.
Message 6 of 10
(4,557 Views)
I'm not sure why you are asking about the Excel ActiveX Object Model on a LabVIEW forum. You're better off asking about that on a Microsoft Excel forum. Once you know the proper Excel properies/methods to use, then you can do the same thing in LabVIEW.
Message 7 of 10
(4,500 Views)
There is not "table" object in Excel object model   http://msdn.microsoft.com/en-us/library/bb149081%28v=office.12%29.
What the heck are you talking about?????
Message 8 of 10
(4,496 Views)
Please see attached excel worksheet to see the table that I am asking about.  It has a simple table but explains what I need to do in comments below it....
Message 9 of 10
(4,487 Views)
Accepted by id
You may think it is a table, but in the Excel Object Model, there isn't such thing as a "Table".
If it isn't there, you can't manipulate it.
Message 10 of 10
(4,484 Views)
