delaying a blinking led.
Hello!
I'm using the USB-6009 DAQ and I want to cause a led to blink.
I know how to do this with a while loop, shift register and....
The main problem using this way is that the time when the led is OFF equals the time when the led is ON.
For example, I want the led to be ON for 0.4 Seconds and then OFF for 0.5 Seconds, then again ON for 0.4 Seconds and OFF for 0.5 Seconds(LOOP).
How can I do this with my Hardware?
Thanks alot,
                ADI.
(3,709 Views)
It's just as simple as writing a digital 1, delay .4 sec, write a digital 0, delay .5 sec, loop.
(3,699 Views)
A rough example of this
Message Edited by LV_Pro on 03-24-2007 12:12 PM
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,692 Views)
You could use a timed loop. It simplifies a few things.
Here's a quick draft.
Message Edited by altenbach on 03-24-2007 10:20 AM
(3,683 Views)
have you traied using a square wave?
i wasn't able to test the vi, i hope it will work and help 😛
(3,675 Views)
