Set Busy cursor does not work for a VI that is dynamically run
The cursor functions (Set busy and unset busy) usually work well when they are used in a VI that is statically run (either a top VI or a VI called from within a VI).
However, when they are used in a VI that is openned and run dynamically (using the VI server) I get an error message:
LabVIEW:  Null window.
NI-488:  Wait in progress on specified input handle.
How can I solve this problem?
(3,977 Views)
I'm not sure why that would happen, but if you could post a small set of VIs that demonstrates this, I'd be interested helping figure out why this is happening.
As a workaround, you might try explicitly wiring a VI reference for the VI for whose panel you want the cursor to go busy into the Set Busy VI.
Good luck!
(3,966 Views)
Hello Jeff
I have just talked to the support people. This is a recognized bug and will be corrected in the next release. They said there is no workaround at this time.
Thank you for your help.
Regards
Bruno
(3,970 Views)
G Toolbox ($) can set cursor style, long before NI implemented this feature in LabVIEW.
George Zou
(3,949 Views)
