deconvolution
I have a quick question about the deconvolution VI. Would X*Y be my raw signal built of amplitude and time and the Y input of the function be just amplitudes?
(5,599 Views)
No. Makes absolutely no sense!
What does the signal represent and what are you trying to analyze using deconvolution? What should the deconvolution output tell you?
Both inputs are 1D arrays in your case so how exactly are you trying to bring "amplitude and time" into one of them?
(5,589 Views)
ugh this is super frustrating. The signal represents square waves in a saline solution. The output should tell me a certain time at which the electrode is active. This will eventually be used for cardiac tissue. This is my first time using deconvolution or even hearing about it. So im learning as I go. Im just confused on what I need to run this function. The example has 2D arrays going into it so i was going to try to follow along that path.
(5,586 Views)
Deconvolution is the wrong function for that. (In certain fields the term "decovolution" is abused to mean a generic analysis. Who suggested to use "deconvolution"? Do you have a reference link describing the analysis you are trying to do?). Deconvolution in LabVIEW is a division in the fourier domain and I don't see how it can tell you anything about time of activity.
Obvously this is not a LabVIEW problem but a math issue. Can you explain in detail how the signal looks like and what you are trying to read out of it?
(5,570 Views)
It may be. The article that suggested using deconvolution did not explain how they did it.
http://circ.ahajournals.org/content/94/10/2633
I am trying to do something similar to this article. Right now I am using peak detector to find activation times. Sometimes this method is not very accurate, so I am looking for a more accurate way to do that.
(5,556 Views)
OK, yes they are using deconvolution. Posting by phone, cannot look at details.
(5,540 Views)
yes they dont really explain the details which makes this harder.
(5,531 Views)
