decimal string to number problems
Hi all,
I'm trying to get the numbers from a string i got from an external device into a spreadsheet file, but it wont let me..
can somebody help me?
(the string contains 3 letters, one space and then 4 numbers)
(I also tried to connect it to both the 1-d and the 2-d connectors)
(yes I set the spreadsheet-write-vi to integer)
thanks
(5,991 Views)
Please post whatever VI you have already, as well as some sample data.
(5,987 Views)
What else do you need to know?
(5,979 Views)
If you look at the error help (ctrl-l) you can see that the 'Write spreadsheet file' functions wants and 1D or 2D array of numbers).
You give the function a scalar, to get this working use an 'build array' function.
You can get the same error info if you hover the broken wire.
Ton
Message Edited by TonP on 10-02-2008 05:01 PM
My LabVIEW Ideas
(5,971 Views)
Accepted by topic author milo_unlimited
Thanks!
i never would've found that out by myself 😄
(5,933 Views)
