decimal string to number problems
Hi all,
I'm trying to get the numbers from a string i got from an external device into a spreadsheet file, but it wont let me..
can somebody help me?
(the string contains 3 letters, one space and then 4 numbers)
(I also tried to connect it to both the 1-d and the 2-d connectors)
(yes I set the spreadsheet-write-vi to integer)
thanks
(5,974 Views)
Please post whatever VI you have already, as well as some sample data.
(5,970 Views)
What else do you need to know?
(5,962 Views)
If you look at the error help (ctrl-l) you can see that the 'Write spreadsheet file' functions wants and 1D or 2D array of numbers).
You give the function a scalar, to get this working use an 'build array' function.
You can get the same error info if you hover the broken wire.
Ton
Message Edited by TonP on 10-02-2008 05:01 PM
My LabVIEW Ideas
(5,954 Views)
Accepted by milo_unlimited
Thanks!
i never would've found that out by myself 😄
(5,916 Views)
